Reinstallation problem
  • G
    Giuseppe Sbirziola
    Hi, I received a message about javascript problems updating and I decided to uninstall the program and reinstall but now this message always appears. Can anyone help me?![alt text](Immagine 2025-01-25 235058.png image url)
    R 1 Reply Last reply Jan 25, 2025, 11:38 PM Reply Quote 0
    • R
      Russ @Giuseppe Sbirziola
      @Giuseppe-Sbirziola, please create this file:
      C:\Users\gsbir\.TRIGGERcmdData\home_assistant_config.json
      With these contents (the defaults):
          "HA_URL": "ws://homeassistant.local:8123/api/websocket",
          "HA_TOKEN": "Put your home assistant token here",
          "HA_ENABLED": false
      That should solve it.
      G 1 Reply Last reply Jan 25, 2025, 11:59 PM Reply Quote 0
      • G
        Giuseppe Sbirziola @Russ
        @Russ thanks it worked, when I restart windows now it reappears and works but when I click on update agent now this appears2.png
        G 1 Reply Last reply Jan 26, 2025, 12:07 AM Reply Quote 0
        • G
          Giuseppe Sbirziola @Giuseppe Sbirziola
          @Giuseppe-Sbirziola furthermore, if I create a trigger from the app it doesn't appear on my web browser account profile and when I restart the PC it disappears3.png
          R 1 Reply Last reply Jan 26, 2025, 1:02 AM Reply Quote 0
          • R
            @Giuseppe-Sbirziola, sorry about this. Will you please try this?
            1. Right-click the TRIGGERcmd Agent tray icon and click Quit.
            2. Reopen the TRIGGERcmd Agent app, and see if it creates the missing command. If it does, stop, you're done. If it does not, try the following next steps:
            3. Uninstall the TRIGGERcmd Agent app.
            4. Delete your computer with the Delete button on the website.
            5. Rename this folder:
            1. Reinstall the TRIGGERcmd Agent app. It will ask for your token again and re-create your computer with the 2 default commands.
            2. Recreate your commands manually, or copy your commands.json file from the renamed folder into your new .TRIGGERcmdData folder.
            R 1 Reply Last reply Jan 28, 2025, 3:12 AM Reply Quote 0
            • R
              Russ @Russ
              @Giuseppe-Sbirziola , I got your direct message. I'm glad that worked.
              1 out of 6
